Originally Posted By: c3po
I believe this is called a Pump Inlet Machine, I read about this a while back.
As you can see they drop the pan and this method gets all of the trans fluid out. Instead of needing 12 quarts with a T-Tech machine you would need something like 20 quarts of trans fluid.
Basically this attaches where your trans filter mounts and all of the old fluid gets pumped out, it goes through the inside of your transmission and torque converter getting all of that fluid out.
This is better than a T-Tech because all a T-Tech does is change the trans fluid in the pan and cooler lines, it does not address the torque converter where the majority of the trans fluid is.
If someone would be so kind since I cannot do this, go to Google and type in Transmission Pump Inlet Machine, and there is a great article explaining this.
I have read that the flow of transmission fluid in a transmission is different in that the fluid does not go from point a to point b and come back again and start over. It basically splits in half, some goes to the cooler lines and some goes to the torque converter.
The torque converter is where most of the heat in an automatic transmission is generated so fluid leaves directly from the torque converter to the cooler, any machine that hooks in the cooler lines is getting the torque converter as well
