2015 silverado dealer oil change
by Realtech214
02/09/16 08:27 PM
delo 400 $17/gallon at walmart now?
by motor_oil_madman
02/09/16 08:23 PM
Looks like Classics are going bye,bye at WM
by chainblu
02/09/16 08:18 PM
acdelco ph64
by gabriel9766
02/09/16 08:11 PM
Using USED oil as a top off?
by Vern_in_IL
02/09/16 07:57 PM
Question-Buying from a rental agency
by powayroger
02/09/16 07:31 PM
2010 G37xS Schaeffer's 5W30 6,800 miles, 102K
by nighamreuki
02/09/16 07:20 PM
TYC Cabin Air Filters
by DrRoughneck
02/09/16 07:19 PM
Time to vent...shop damaged wheel...again!
by gregk24
02/09/16 07:07 PM
Wooden Box Retirement Gift
by doitmyself
02/09/16 07:03 PM
PL30001 Cut open
by Dyusik
02/09/16 06:47 PM
Founder of BlackStone Labs passes away
by JetStar
02/09/16 06:10 PM
paulp, ATLjunkcars, jqgz, ukpdxwrx, TerrenceRocks
56865 Registered Users
112 registered (69GTX, 04SE, 97f150, AlienBug, AandPDan, AEHaas, 9 invisible), 1525 Guests and 222 Spiders online.
56865 Members
66 Forums
244468 Topics
#1543943 - 07/25/09 03:42 PM Oil Viscosity question,Honeywell Generator
AndrewM Offline
Loc: IL
Hello,
I just recently purchased a Honeywell Hw2000i generator. The Oil recommendation is 15w-40 API rating of SF or better. Honeywell told me I can use any 15w-40 as long as it is not specifically formulated for diesel engines. Kinda hard to find. I ended up finding Shell Rotella T that is formulated for both gasoline and diesel. Now my question.
Shell advertises Sythetic Rotella T 5w-40 that out performs its coventional 15w-40. Does that mean I can safely run this in my generator? It has API rating of SL. I understand the API ratings, I am curious if I change the weight if it could have adverse effects.
Thanks,
AndrewM
#1543958 - 07/25/09 03:58 PM Re: Oil Viscosity question,Honeywell Generator [Re: AndrewM]
Pete591 Offline
Loc: Michigan
A 5W-40 synthetic with an SL rating is probably your best way to go year 'round.
#1543980 - 07/25/09 04:20 PM Re: Oil Viscosity question,Honeywell Generator [Re: Pete591]
javacontour Offline
Loc: Illinois
If the oil has both gas and diesel ratings it should be fine. I.E a 15W40 that has both SL and the corresponding "C" rating should work.
I think what Honeywell is saying is don't use an oil that only has the "C" rating.
network down, IP packets delivered via UPS -BOFH
#1544108 - 07/25/09 07:34 PM Re: Oil Viscosity question,Honeywell Generator [Re: AndrewM]
JTK Offline
Loc: Buffalo, NY
 Originally Posted By: AndrewM
..Honeywell told me I can use any 15w-40 as long as it is not specifically formulated for diesel engines.
Gas or diesel rated isn't a concern at all. That's old school misinformation (C-rated only oil as Java stated). I'm glad to see a 40wt spec for a small air cooled OHV engine for once! Nice little inverter unit BTW.
J[code][/code]
el
Edited by JTK (07/25/09 07:35 PM)
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#1544121 - 07/25/09 07:49 PM Re: Oil Viscosity question,Honeywell Generator [Re: JTK]
JR Offline
Loc: Michigan born but my heart bel...
how much did that set you back? if u dont mind me asking. what are the spec and ratings?
kc
#1544159 - 07/25/09 08:26 PM Re: Oil Viscosity question,Honeywell Generator [Re: JR]
JTK Offline
Loc: Buffalo, NY
Yikes! >> http://www.electricgeneratorsdirect.com/Honeywell-HW2000i/p2569.html
Joel
#1544183 - 07/25/09 08:56 PM Re: Oil Viscosity question,Honeywell Generator [Re: JTK]
Pete591 Offline
Loc: Michigan
Looks like a small engine for a 40wt....what type and HP engine is it?
#1544252 - 07/25/09 09:57 PM Re: Oil Viscosity question,Honeywell Generator [Re: Pete591]
JTK Offline
Loc: Buffalo, NY
Honeywell lists it only as "4-Stroke, Single Cylinder, Air-Cooled, OHV, 125cc, big bore." 125cc is approx a 3-4hp. It's probably a little OHV Chinese made engine.
Joel
