Originally Posted By: callbay
Volvohead, What is your opinion of 5-50 Castrol Syntec for marine use? Would you say it is like your description of 20-50 and 15-50 or you would not use it like your description of 0-40?
Thanks!
I'd shy away from it. It's likely a Group III with a complex VII package. Oils with more complex VI chemistry, such as M1 0w-40, are outstanding performers in automotive use, but not necessarily the best pick here. I'm not saying it won't work out just fine, but there is a higher risk of problems with them. Whether you want to take that risk with a $15,000+ marine engine is up to you.
I know that this is entirely counterculture to what's propounded elsewhere around BITOG. But the unique conditions of marine duty really separate the men from the boys chemically. The marine lubricating environment is almost neanderthal compared to what goes on on land. High tech doesn't necessarily work in a lot of marine engines, which, by the way, are at heart still low tech themselves. Things like FWC and FI help, but it's still a wet, fuel rich environment.
I'm not saying to run QS HD30. But oils that are generally chemically very stable tend to put up with marine conditions better. The only auto analogy I can come up with is a BMW engine recently discussed on an import oil thread that was destroying PCMOs with high shear/high fuel dilution conditions. BMW's solution was . . . a higher viscosity oil. And from the post, the only other oil that could put up with it was RLI.
