Originally Posted By: MolaKule
Quote:
boy not much for adds?,must be all i nthe base stock???
This is for a low ash synthetic formulation, but the additive pack may vary among manfacturers.
Generally, you want a low ash formulation for low deposits.
The base oils are a combination of Group IV and V's such as PAO's, esters, and polyisobutylenes (for low smoke formulations).
The other additives are anti-oxidants, anti-corrosion, metal deactivators, and high molecular weight dispersants.
Quote:
yamalube has 700moly and 250 p
Where did you get that data? Is that for a mineral TWO-cycle lube? That seems high to me. Some formulations use the moly for combustion improvements AND for friction reduction, but the right selection of base oils will get you good lubricity and friction reduction.
Nice info MolaKule thanks, let me ask you IYO how is yamalube compaired to amsoil's interceptor? any idea at all?
