Originally Posted By: TLC3
Lucas trans additive works great had a s10 4x4 blaser that would not even hardly pull change fluid added lucas and it works just like she did on day one!
I'll bet the fresh fluid did more than the Lucas.
I added a bottle of Lucas with a fresh fluid change on my 97 Subaru Legacy with 185k miles. I had the same shudder mentioned before so I flushed it out, and replaced it with Amsoil ATF. Still shifts hard into second, but no more shudder.
Now, if I can only figure out how to get the tranny to shift properly into 3rd. She seems to downshift into 4th from 2nd for a full second or two before finally upshifting to 3rd. The subsequent shift from 3rd to 4th is perfect. It has not changed in the 20k miles I've owned the car, and gets better when the car has been run for a half hour or so. At at a loss really. Planning to change out the fluid again in another 10-15k miles or sooner if things change.
