I was recently comparing the same size filters for the same vehicle and noticed that some manufacturers use different bypass valve pressures. Purolator seemed to be higher that Wix. Some companies don't provide a lot of data. Should I be concerned about the pressure? Would lower or higher be better? I imagine a lower pressure would prevent the media from bursting but might dump unfiltered oil through the engine.
Why wouldn't the filter companies need to use the same bypass valve pressures to maintain new car warranties?
Thanks
Thanks
