Which Oil
by Jamn
06/29/16 02:11 AM
Oil for Binding Foundry Sand
by smw
06/29/16 01:38 AM
Found a good high zinc breakin oil
by 1977c10phxdriver
06/29/16 01:12 AM
What is this radio modulating sound?
by Pontual
06/29/16 01:00 AM
The reason brake fluid can be Dot 3&4 - Viscosity!
by CharlieBauer
06/29/16 12:56 AM
No injector pulse, '92 Prelude, F20B, GSR ECM
by redhat
06/29/16 12:02 AM
Finding #1 Cylinder
by motorguy222
06/28/16 11:31 PM
Sure Filter 2821A C&P
by funflyer
06/28/16 11:27 PM
Can Kies save multiple phone info?
by daves66nova
06/28/16 11:25 PM
Tie-Rod Brands? AcDelco, B&A, Mevotech, MOOG
by Mr_Accord
06/28/16 10:23 PM
Engineer and Frog
by Koop
06/28/16 09:05 PM
Chevy 6.2 Silverado, Shaffer's or Mobile 1
by Crobinson16
06/28/16 08:32 PM
dougsangster, CrazyCalvinW, mal86, smw, Crobinson16
58311 Registered Users
30 registered (c502cid, Boczech, Darris, BrianF, Chris B., carlprop, 3 invisible), 814 Guests and 21 Spiders online.
58311 Members
66 Forums
250964 Topics
Page 2 of 4 < 1 2 3 4 >
#1239396 - 09/19/08 10:28 PM Re: Corolla Ticking - Using 10w40 and Auto RX [Re: saaber1]
crazyoildude Offline
Loc: New Jersey
Maybe so but one is not a 98 corolla
#1239401 - 09/19/08 10:35 PM Re: Corolla Ticking - Using 10w40 and Auto RX [Re: 105]
Loc: New Jersey
again 5w30 with a good oil filter as long as you did not blow it up with all the experements
corolla engines are good for over 200,000 miles and if all engines were built that way i would be out of the engine business.
A word to the wise if it aint broke dont fix it Period!
That engine calls for 5w30 not 10w40 or 5w20 5w30 is really what toyota calls for.. Hope your engine is ok
#1239411 - 09/19/08 10:50 PM Re: Corolla Ticking - Using 10w40 and Auto RX [Re: XCELERATIONRULES]
Loc: New Jersey
i agree with that but follow the engine builders guidelines and use what they tell you some people think 5w20 oil is too thin for the ford modular v8 and the new dodge hemi but we found out that 5w20 seems to be the best wear wise and even most of the New Jersey State Troopers are using 5w20 now , they also tried the rest and learned the hard way through blown out oil filters in those engines that the 5w20 is a great oil. Although i have seen some use 5w30 with no problems 5w20 is a great oil as long as it meets sm gf-4 and has the certified starburst symbol..In the old days thicker was better now with modern oils thin is in.
#1239847 - 09/20/08 06:06 PM Re: Corolla Ticking - Using 10w40 and Auto RX [Re: crazyoildude]
105 Offline
Loc: Louisville, KY
I took the belt off and no luck. I got under the car and its definately louder there and near the rear of the motor.
2001 Chevrolet Camaro Z28 M6
1998 Toyota Corolla VE A3
#1239848 - 09/20/08 06:07 PM Re: Corolla Ticking - Using 10w40 and Auto RX [Re: 105]
chevrofreak Offline
Loc: Billings, MT
That makes me wonder if it's an oil pump issue.
I <3 Red Line oil
#1241108 - 09/22/08 08:01 PM Re: Corolla Ticking - Using 10w40 and Auto RX [Re: chevrofreak]
105 Offline
Loc: Louisville, KY
#1241127 - 09/22/08 08:25 PM Re: Corolla Ticking - Using 10w40 and Auto RX [Re: 105]
Gary Allan Offline
Loc: Pottstown, PA
Hot or cold? Both?
http://lube-direct.com/gallan/
#1241153 - 09/22/08 08:54 PM Re: Corolla Ticking - Using 10w40 and Auto RX [Re: Gary Allan]
Liquid_Turbo Offline
Loc: Vancouver, BC
Something to do with valve adjustment maybe?
#1241185 - 09/22/08 09:51 PM Re: Corolla Ticking - Using 10w40 and Auto RX [Re: Liquid_Turbo]
mikered30 Offline
Loc: PA
Bearing, lifter, rod, or injector? Are all of your vacuum lines attached correctly? Did you check the color of your spark plugs and how old are they? Do you have access to a stethoscope to pinpoint the location? Does the 98 have a timing chain or was that the first year for a timing belt?
Edited by mikered30 (09/22/08 10:00 PM)
#1241351 - 09/23/08 05:50 AM Re: Corolla Ticking - Using 10w40 and Auto RX [Re: 105]
INDYMAC Offline
Loc: Magnolia, TX
If your engine has a timing chain, I would say that the timing chain auto-tensioner has gone south.
2013 Toyota Tundra DC 4X4 5.7L FFV
2012 Toyota 4Runner 2WD SR5
2004 Honda S2000
#1241391 - 09/23/08 07:32 AM Re: Corolla Ticking - Using 10w40 and Auto RX [Re: INDYMAC]
105 Offline
Loc: Louisville, KY
I'm gonna listen to it agian, but it sounded loudest from underneath the car last time. It does have a timing chain. The spark plugs looked ok to me, just grey. I don't know how long they've been in though.
#1241417 - 09/23/08 08:34 AM Re: Corolla Ticking - Using 10w40 and Auto RX [Re: 105]
105 Offline
Loc: Louisville, KY
Also, when I was under the car I could swear it was coming from the manifold area. Could this possibly be an exhaust leak?
#1241463 - 09/23/08 09:47 AM Re: Corolla Ticking - Using 10w40 and Auto RX [Re: 105]
Gary Allan Offline
Loc: Pottstown, PA
I know it's not going to relieve your anxiety, but I'd suggest just riding it out. The noise is the result of something draining down faster than it's supplied with oil (imo). Once the supply feed gets cleaned up (over the various flow division options that it has at that point in the system), it should be back in balance and quiet down.
#1241520 - 09/23/08 11:45 AM Re: Corolla Ticking - Using 10w40 and Auto RX [Re: Gary Allan]
105 Offline
Loc: Louisville, KY
I'm hoping you're right. I'm planning on riding it out till I'm into the next oil change/auto rx rinse and see what happens.
Edited by 105 (09/23/08 11:45 AM)
#1241736 - 09/23/08 03:56 PM Re: Corolla Ticking - Using 10w40 and Auto RX [Re: 105]
INDYMAC Offline
Loc: Magnolia, TX
Here's what a bad timing chain auto-tensioner sounds like in a Honda S2000:
http://www.youtube.com/watch?v=NwFVZADoyx0
2004 Honda S2000
