From my experience cleaning up the seals is all that has been necessary. I would consider running a cleaning dose of ARX, followed by a mineral oil dino rinse, before resorting to oils or additives designed to swell seals. I say this because many times contaminants build up on rotating shafts and the sealing interface, starving the seal from lubrication. This would also hold true for valve stem seals and guides. Polymer seals would like to rebound if they were allowed to do so. At the end of the day if the ARX approach does not get the perfect result, then you may wish to explore swelling alternatives. But this can be a short term gain with long term negative results. But by cleaning the seals and related area first, at least the seal swelling chemistry will perform equally around the circumerence of the problematic seal. Just my 2 cents.
