Some History:
I performed the first drain/fill on my wife's 2006 Pilot at 27,000 miles in March 2007. At that time, I opted to use Honda Z1 ATF. The factory fill ATF was dark and there was a lot of metal sludge on the magnetic drain plug, so I began to look for a more robust ATF to use the next time. I also decided to perform an ATF drain/fill every other oil change, which works out to ~10,000 miles. After careful consideration, and much research on BITOG, I decided to use Amsoil ATF.
Fast Forward to April 2008:
Since the last ATF drain/fill in March 2007, I had started to get concerned about how rough the transmission was sounding. The switch from 1st to 2nd gear sounded especially ragged until the transmission reached operating temperature. All in all, I felt that things should be smoother, less noisy.
5/24/2008:
At 37,500 miles, my wife's Pilot was due for an oil change. This was the 2nd engine oil change since the last ATF drain/fill, so I knew that it was also time to perform an ATF drain/fill. For engine oil, I opted to use to Amsoil 0W-20 with a Wix 51356 filter. I have always used either Mobil 1 or PP 5W-20, but wanted something more robust. My wife's does a lot of short trip driving and the heat of the Texas Summer is rough on an engine. The 2006 Pilot LX 2WD has a total ATF fill of 8.9 quarts. Once again the Honda Z1 ATF was dark and there was a lot of metal on the magnetic drain plug. One ATF drain/fill takes 4 quarts, and 4 ounces, so the mix now stands at 46% Amsoil ATF and 54% Honda Z1 ATF.
Results:
The engine runs smoother and makes less noise, both at idle and at speed. The transmission is less noisy as well. Shift quality has definitely improved, especially during the transition from 1st to 2nd gear when the transmission is cold. I had been concerned about using anything other than Honda Z1 ATF, but I now feel that the Amsoil ATF is a better fluid. At this point, I am planning to perform an ATF drain/fill during each of the next 2-3 oil changes to get the Amsoil ATF up to the recommended 90%+ concentration. If I get bored, I may end up performing ATF drain/fills using a more aggressive schedule.
Stay tuned...
5/24/2008:
Results:
Stay tuned...
