In a performance application on a Chevy 383 what oil would be better?Mobil 1 Extended Performance 15W-50 or Pennzoil Platinum 15W-50. The car does not see a lot of miles but is driven hard and sees some good revs.
I would use Mobil 1 15W-50 its available just about anywhere so in case you need to top it off. How about using the regular Mobil 1 15W-50 non EP since you don't do a lot of miles on that car. I've never seen the Pennzoil Platinum 15W-50 anywhere before.
Nice car by the way, engine sounds cool. What oil you running on it right now?
The EP lineup in Mobil 1 is a joke. Get the non-EP Mobil 1 15W-50 or PP 15W-50. There is very little UOA data on these oils that I've seen. Pick one and try it. Then decide later if you want to try the other.
Originally Posted By: 321
Thanks for the web look!!
Under your rocker covers is that a special coating or some kind of paint??
And do you trust it to stay intact?
It is a $7 can of duplicolor engine enamel that is good to 1200 degrees. If it gets that hot I can say good bye to my forged aluminum pistons anyway. Been using that stuff for a while and it holds up great. It provides a slick surface for the oil to drain back the sump quicker. Lots of custom engine builders use this trick.
Glyptal is what we used on the J-79 jet engine that was in the F-4 Phantom jet fighter. It was used back in the turbine section bearing area as a gasket sealer. I have read that several engine builders use it to paint the inside of their engines for better oil flow. Remember the the better the flow then better heat transfer. I look at it like this, if Glyptal is good enough to go inside a jet engine especially the hot section as well as in the oil bearing area then it will hold up to our simple automotive engines. 7808 jet engine oil will do a good job of cleaning out our automotive engines as well as all the seals and such and the Glyptal held up fine against all that.
