Just got back from dropping my Audi S4 off at the shop. Had it faltbedded back from NJ. On my way back from NY, I couldn't avoid a large object that fell off a truck in front of me. Turned out to be the pad form an outrigger. Unfortunately my car was too low and it put a huge hole in the cast aluminum oil pan. I drug it along until I could get the car stopped on the shoulder. When i saw smoke, I immediately turned it off. Huge puddle of oil under the car. No oil loights went on and the engine sounded fine until I turned it off. What do you think? can GC protect the engine after the oil is drained out? :-( Time to finish my scotch now
