The graph is misleading
"The study was conducted in the following manner:
-The independent research firm obtained a quantity of “untreated” ULSD fuel
from a supplier. This fuel was basic ULSD fuel intended for use in diesel
engines. However, this sample was acquired PRIOR to any attempt to
additize the fuel for the purpose of replacing lost lubricity. In other words, it
was a “worst case scenario, very dry diesel fuel” that would likely cause
damage to any fuel delivery system. The fuel was tested using the HFRR
testing facility at the Laboratory. This fuel was determined to have a
very high HFRR score of 636 microns, typical of an untreated ULSD
fuel. It was determined that this batch of fuel would be utilized as the
baseline fuel for testing all of the additives. The baseline fuel HFRR score of
636 would be used as the control sample. All additives tested would be
evaluated on their ability to replace lost lubricity to the fuel by comparing
their scores to the control sample. Any score under 636 shows improvement
to the fuels ability to lubricate the fuel delivery system of a diesel engine."
The whole post needs to read. 550 HFR is what most fuel is or was before USLD . In reality the fuel used for testing was not from a pump or pump grade. In reality the majority of the additives do help
