European diesel needs to be 51 cetane minimum. And some of it comes from the USA. So maybe not such a specialty product afterall. Ours is up to 7% biodiesel.
Your absolutely correct, and most people don't understand the difference. I would guess the renewable diesel is made by the Chevron refinery there, they have been investing a lot in that process. Purely a guess.One other point is that “ Bio Diesel” is not the same as “ Renewable Diesel”. We have the sloppy reporting by the main stream press to thank for that.
It’s “Renewable diesel” that’s in a large growth mode in California. Although they both originate from similar stocks, “Renewable Diesel” is highly refined and can absolutely take the place of conventional diesel.
Here is something from Exxon regarding their refining process.
Most “Renewable Diesel” is refined in the large chemical infrastructure in Louisiana and is shipped to California. At least five other states now have processing capability.
I had to take a look at how Renewable diesel is being marketed. Here is something from Chevron.
I’m no expert on this but let’s see what the year end numbers are. Imports from Singapore were growing rapidly in 2023. I sense “ rumours of its demise were greatly exaggerated.”Renewable diesel is refined at multiple locations by P66, Chevron, and Marathon. Your chart is dated, likely the majority or all is manufactured in the state now.
Neste fuels are not imported any longer as there is enough domestic capacity.
It is sold a branded fuel by Chevron, 76, and Propel. Some Indy stations also sell it, as in Berkeley at biofuel oasis.
There are 5 refineries in Northern California. Conventional diesel would most likely be from one of them,
Usually your local gas station will get their fuel from the same distribution center as all the other local gas stations. The primary difference is the add pack. The base fuel itself is stored at the distribution center, the trucks pull in, fill, dump the add pack in and there off.
Rare exceptions are possible where your equidistant between 2 distribution points. I live near one of those - we have a nearby DC fed by pipeline, but also a Kinder Morgan DC in the port that comes in by ship. I think the ship one might only be diesel. I have tried to find out but such things aren't published really.
So even if I knew where the local 7-eleven sourced there diesel from, it might be completely different from where you are, but likely isn't that much different from other stations in the area.
Having said all that - I have no clue how bio diesel works, so it might be totally different.
Here in the Midwest all diesel is B5 and the pump has to be marked if greater than B5. Most fuel in the Iowa and Illinois area is B5-B20.
FWIW @CleverUserName i think you are wasting your money with an additive at every fill up. I am curious to know what is the point of the additive?
Just my $0.02
I’ll take your word for it. I’m wondering how a fuel additives effects your oil analysis but I digress.You can research my oil analysis I’ve posted on here since 2018. They indicate the additive I’m using has positive effects.
Just my $0.02
Correct I don’t use any oil additives. I don’t see a need. My Cummins runs just fine without any and I’ve done several UOAs.You probably have never used different additives followed with oil analysis.
Oil analysis can be used to see how combustion is occurring inside the engine.
Just my $0.02
