Originally Posted By: wrcsixeight
I am in San Diego, But I have my homemade U tube style antenna pointed at mount Wilson above LA, 92 miles away, and I get, or with a little tweaking, can get every station broadcast from that mountain.
The humidity seems to be the biggest climatological factor in my reception(fog is good, Santa Anas bad). While pointing my antenna, it really needs to be within 5 degrees of exact to pull in the weakest of stations, another factor, how far forward or back it leans also has a huge effect on reception. Some frequencies( channels) need the antenna to be rotated e/w depending on many factors, despite the towers being the exact same direction.
My neighbor has a channelmaster antenna that does not perform that much better considering how much bigger, and professional it is. That antenna can only pull in the strongest stations from it's backside, whereas my homemade antenna seems to have 75% the gain on the back of the antenna as compared to the Front.
Hmmm, I think i should be very good,considering you can get the stations 92 miles away.I'm only 17 miles away.
