Originally Posted By: SilverC6
Originally Posted By: ZeeOSix
Not good enough for me ... engines don't like "hair balls". LOL
It also means it's catching much less of the particles that are smaller than 20 microns, the particles that do the most wear.
But you can choose any oil filter you so desire, and if you're happy with the XP then that's all that counts.
Sub-20 micron particles in motor oil cause most of the wear in engines?
No, not in automotive applications.
Capturing sub-20 micron particles in engine filtration is seen in over-the-road trucks trying to "remanufacture" the oil it its sump in an attempt to reduce the cost of oil changes.
Go read some white papers on engine wear. Automotive engines are just as prone to wear as any other engine on the road.
So again, stop the hyperbole regarding the Wix XP efficiency.
You best call up WIX and ask them to make a more efficient filter first.
If Toyota Camrys can go 400,000 miles on OEM oil filters with similar efficiency as the XP, sub-20 micron particles are clearly not a factor in automotive engine wear.
Pretty much anyone here knows that an oil filter with 99% efficiency at 20 microns vs one at 50% at 20 microns is going to remove more wear particles from the oil. Have you did a study to compare the wear (by engine tear downs) in two identical engines using extremely different efficiency oil filters over 400K miles to say there is no wear difference to come up with your wear conclusion? Engines can get pretty worn out and give the perception of still running just fine. Just because it still runs well at 400K miles doesn't mean it's not worn pretty good.
But now they are a concern in marketing materials for some commercial filter manufacturers and a few OCD-consumed BITOG zealots.
Yeah, all the high efficiency oil filters invented and on the market are all doing no good and are all just "marketing hype". Sure ... LOL.
