Winter Oil Change--Filter Brand Change!
Originally Posted By: daman
Where would one go to find out about Wix XE oil filters?
Never heard of them. Not on Wix's website either.
Nevermind I found them.
There a pretty cool filter huh?
Yes. Too bad there aren't any for my application.
bottom line in filters its better to have a filter that flows better than to have a filter that filters better and restricts oil flow, period!
dirty oil lubricated much better than no oil
-Syn-,
If you're worried about $4000 injectors, then install a bypass oil filter. I doubt that differences among the full-flows would improve anything. Try the Pureone filter.
Usually when the oil filter doesn't have a bypass, its in the filter mount or engine block. This means that your application doesn't need a filter with a built-in bypass.
Right and you won't their a fleet application only,heavy trucks and equipment.
You'll never have a restriction or flow limitations because if you do the pressure by pass will open thats what it's there for, it's purpose.
