Originally Posted By: itguy08
Originally Posted By: Thermo1223
Those little guys are spinning faster and faster operating at higher EGT's than a diesel would sans regen. Then there is motor oil. While new and taken care of by a competent owner I see no issues. However the goofs who give Jiffy Lube and Shady Mechanics $$$ are most likely not using the correct oil.
That can and will be a costly repair in the future especially considering the number that are DI with regards to deposits from oil flash off. Gasoline are also a lot higher stressed than the comparable diesel. A mechanical failure in a diesel on the lower engine is few and infrequent but on turbocharged gasoline engines it is almost expected.
So while there are pluses there are also quite a few minuses.
Don't take it as an insult to the technology I want more of it but there is always a catch.
Well, Ford has over 5 Million Ecoboosts out there since 2009 (
http://www.usatoday.com/story/money/cars/2015/03/17/ford-ecoboost-milestone/24887671/) and turbo and general engine problems are far between.
I do nothing special to mine and at 90k it still runs like a top. I don't consciously idle it, change the oil when the OLM goes off, use the cheapest swill I can find, etc.
Turbos for the EB go for about $800 ea so while it could be expensive, it's less than a transmission.
I wouldn't advise using the cheapest swill, IMO. Synthetic in turbos and nothing else.
I don't idle mine either, watercooled turbo's don't really need it. I would follow the OLM just like you.
Don't worry the same stuff can go wrong on diesels too. If anything we are padding IHI, BW, Mitsu, stocks with all the turbo's these days lol.
In fact I see the 2.0l ecoboost uses a K03 just like older Jettas.
