Hi,
jaj - yes there is actually two versions today - a PAO (via Castrol) and the "ester" (via BMW) - the ester version is the original. It was originally of 15W-50 viscosity, red in colour and of a castor base - ahhhhhhh that exhaust smell......quote]
Hi Doug,
Just to clarify, are you saying that Castrol Edge 10W60 (now called Castrol Edge FST 10W60 for M engines) is PAO based and Castrol TWS (only available from main dealer) is Ester based? Here in the UK we are of the understanding that TWS and Edge 10W60 are the exact same product and formulation, the names only differ as one is sold by main dealer and the other is available from resellers. Even well known distributors like Opie Oils confirm that it is the same. Sorry, not doubting you just wanting clarification.
People that are questioning why BMW spec such a heavy oil, well as some have said this isn’t any ordinary 10W60. I also looked into this and will explain what I have found and why I think that this is a very special 60 weight. Firstly, I would just like to say that not all M engines are meant to be running this, especially when it comes to the E36 M3 as the Euro E36 M S50B32 engine is very different to the US S50/S52. The US one is more of a bored out 328 engine where as the Euro S50 is more closer to the S54 (E46 M3 engine) with its ITB etc… which give it much more power and torque Hence the heavier oil spec. Main thing with the TWS/Edge 10W60 is its cold flow properties. It has a cold crank viscosity of 4860cP @ -25 Deg C and a pour point of -51 Deg C! This CCV is close to and even better than some 30 weight oils at -25 Deg C. Most other 60 weight oils are around the 7000cP range. TWS’s viscosity at 100 Deg C is thicker than other 60 weights too. So in actual fact it flows like a 30 weight at start up but at the same time protects better than other 60 weights at operating temp, hence people believing it not being just any 60 weight oil. Other reasons for BMW choosing this viscosity have already been covered.
I’m no expert at oil analysis, not even close; I have just been reading a lot on this site and doing my own research into oils. I have made a large spreadsheet with all the mainstream and racing oils and split it according to viscosities, labelling all the properties of all oils, it was after doing this that I clearly saw the differences between TWS and other 60 weights. If I have misunderstood what CCV is please correct me.
Regards
Kash
Kash - Castrol Edge 10w-60 and Castrol TWS Motorsport 10w-60 (the BMW product's full name) are the same ester based product with the same BMW approvals. Castrol Edge Motorsport 10w-60 is the PAO version that Doug was talking about.
