Originally Posted By: qwertydude
Here's my advice. Like I said. Forget the nano-sponge or nano-towel, I don't know what your obsession with power decontamination is but I'm telling you if you don't have experience detailing cars, power decontamination is simply asking to gouge and mar your paint especially with the nanoskin products if you let them get low on lube. Get clay, it's less expensive, and does a great job, and it's the fastest part of detailing. Saving a minute to power this portion makes no sense. Use that money to buy a DA and save time and do a better job where it really counts, the polishing step.
If you really don't want to get the DA then get a decent polish like Meguiars M205. That and a 6" random orbit polisher, a couple wool bonnets and the M205 will work really well in making your car shine. It won't correct nearly to the degree that the DA does but M205, a wool bonnet and a 6" random orbit can do a lot better than NuFinish regardless of application method. If you haven't really taken the time to pay attention go at night to a well lit parking lot and look at the reflections and you'll see tons of swirls. With that said NuFinish will only make those swirls worse. People never notice just how bad NuFinish is on paint until I correct half their hood and tell them to go back to the parking lot.
And as far as protection goes, Collinite will outlast NuFinish. The reason NuFinish tends to last longer than waxes has as much to do with it's "cleaners" read abrasives. A cleaned and polished surface will bead water longer because protectants hold better to properly prepped surfaces. Waxing contaminated rough paint means the wax can't hold on as strongly and they tend to wear out quicker. But do a proper polish and apply a pure wax like Collinite and the results will look way better than NuFinish, you won't stain your plastic trim, and the protection will last longer.
+1, mostly.
The autoscrub products do require some care and experience, so after a second thought, I think a beginner is better off with using a less-aggressive, traditional clay bar.
However, I would really advise against wool pads of any kind since the fibers themselves will leave marks in the paint:
http://www.autogeekonline.net/forum/wet-...html#post649785
You are much better off with a proper set of polishing and finishing
foam pads.
And the people promoting the nano-products online seem to be promoting them as if they're advertising. I have one, I'd rather use clay. The nano sponge doesn't save me any more time than clay and costs more. No benefit other than it's supposed to last for a hundred cars. And like I've said if you're decontaminating a heavily contaminated car an aggressive clay is better, less damaging and better feel. Clay has much better feedback than the sponge because you can literally feel when you're done with a section, the sponge you can't, clay glides smoothly and noise free over clean paint, then you know you're done. The only product you can feel your progress with is the nanoskin, but on heavily contaminated surfaces it will mar worse than clay.
Basically I see no advantage with the nanoskin products over existing tried and true products. And I'm not some old school fogey about these.
I cannot say that I agree. I've used the Nanoskin Fine grade pad, Riccardo Yellow and Pinnacle Ultra Poly clay - for a moderately contaminated car, the Nanoskine fine grade pad (on 6" DA polisher) remove most/all of the contamination in a fraction of the time without leaving any marring. On the car that I was working on, a traditional clay bar would have taken me at least 3x as long.
Instead a yearly light polishing and regular waxing will keep the paint plenty protected AND looking top notch. Whereas with something like Opticoat, it starts out looking mediocre and only gets worse from there.
For the record, Opticoat can be removed with an aggressive polish - so it is not truly "permanent."
