So many threads and I've never recall a consensus on whether to stick with the *OEM ESSO 71141* fluid or was there alternatives that others have used and felt it was fine....TCC shudder, etc.
I'm planning a brake job soon and while it's up in the air, I'm leaning on dropping the pan and changing the filter on it. The sump holds 9, and when you drop the pan, it's around a 6 Qt change.
I've done 2 drain/refills already without a pan drop and have always used the Esso OEM fluid.
Just wondering outloud of any alternative *compatible* fluids out there, that has known to work well with trannys calling for the 71141 fluid.
I'm not in the mood to experiment with different fluids ;-)
