Want to lift a car off all 4 corner to about 1' off ground and stay leveled. Wheels can touch ground but I need to slide under it safely.
What do you recommend? I'm not sure how to do it at home with just a 2 ton jack and 4 jack stands.
Should I gradually lift it up and prop it on bricks tiles? The biggest car I have is a Ford Taurus (about 3500 lb). I'm thinking rearing up a ramp, then hand brake it, then jack the front up high enough, and put another set of ramp in the opposite direction. Finally put wedges on the front and rear to avoid roll off.
I'm a bit nervous. Only 30 and still have hopefully another 60+ years ahead.
