We own a 06 Jetta TDI with the PD motor. At 65k, the dealer found the #3 injector seal was faulty, and upon further inspection they observed damage to the cylinder bore due to the injector moving around. VW replaced the complete cylinder head under CPO warranty...meaning new injectors, cam, valves...the works.
It's not often you get a "clean slate" on a used vehicle, but this is my opportunity to assure this new cam & head only see quality oils and reasonable OCIs.
Enter a variable I can't control...I'm not the primary driver. The primary driver of this car isn't obsessed with the care of vehicles like I am. To them, the car is a machine and is ready to perform it's task (to drive them) as soon as they turn it on. This means the TDI frequently sees revs beyond 3.5k while the engine is stone cold, and cruising revs beyond 3k if they momentarily forget about 3rd, 4th, or 5th gears. Sometimes, 2nd gear is dispensed with and the engine is momentarily lugged in 3rd. Other times, the engine will see extended warm-up periods of idling in the driveway. It just depends.
I've come to the conclusion that the primary driver is not a variable I can control.
My question is this...what properties should I be looking for in a HDEO that will best work to prevent what the driver is doing to the engine?
I'd planned to run Shell Rotella T6 in this motor because I believe it to have good pumpability at colder temps (min pour point), good oil film strength, reasonably high levels of ZN & P, and all the other reasons people run this oil. However, I'm not sure that I'm considering what properties are most important in an oil for the conditions this oil sees.
Any input is welcome...remember, my question is what properties should I be looking for in an oil that sees this type of service...not your thoughts on what the best OIL is for this application. Tell me what you'd look for in an oil and I'll shop the VOAs for what best suits my budget/availability/brand preference/etc.
Or, is it possible that oil alone can't overcome the physical stresses that this engine will see during daily use. If so, what other controllable variables should I address?
Thanks!
Matt
Thanks!
Matt
