Originally Posted By: Best F100
Since the performance of all the 0W20's and 5W20's are all pretty close (all good), I use the HT/HS figures as a deciding factor (the higher, the better). Consider:
For Example,
HT/HS
2.7 - Mobil 1 5W20EP, Kendall 5W20 Full Synthetic w/Titanium,
Motorcraft 5W20 Full Synthetic
2.8 - Amsoil 0W20
3.3 - Red Line 5W20
The upcoming GF-5 standards may change some of these numbers. But for right now, for my money, it is hard to see any benefits in using anything more expensive than that Motorcraft 5W20 Full Synthetic. It's durability tested by Ford and you will tire of that Fusion, before you wear the engine out (if properly maintained). I recently, raided the Advance Autoparts around here to buy about 35 qts of it @ between $1.50 - $2/qt (clearance price). Using it on a 2010 Ford Focus.
A higher HTHS vis is not better, it simply means the oil has a higher operational viscosity which you usually don't want in a vehicle spec'd for a 20wt oil. Additionally, the higher the HTHS vis (all things being equal) the lower the fuel economy.
All vehicle manufacturers that spec' a 20wt oil expect the HTHS vis to be in the 2.6 cP to 2.7 cP range with the vast majority being closer to 2.6 cP.
For the OP, I also believe all 5W-20 and 0W-20 grade oils are good.
The advantage of the ultra-light 0W-20's from Honda, Toyota, ENEOS, and Edge is that the start-up viscosity is very low even at room temperature. This further minimizes wear and maximizes fuel economy.
