I think it's why they make filters with such high bypass ratings. They must have a tremendous load capacity in the filters to endure that duration of OCI. The media must be very strong and reinforced.
I assume that they have engineered in sufficient buffering in the oil pump in terms of pressure relief ceiling to accomodate the upstream elevated pressures.
Here's the WIX for the VW
Part Number: 51393
UPC Number: 765809513938
Principal Application: Audi (71-05), Volkswagen (96-05)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.820
Outer Diameter Top: 3.020
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 33
Anti-Drain Back Valve: Yes
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.800 2.450 0.230
Here's essentially the same filter for an American car spec ..with probably a 7500 (12,500km) max OCI recommendation.
Part Number: 51516
UPC Number: 765809515161
Principal Application: Ford/Merc. Cars + Trucks (81-05), Chrysler/Jeep (02-05), Mazda Trucks (94-05)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.828
Outer Diameter Top: 2.921
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Gasket Diameters
Attached 2.734 2.430 0.226
[ June 14, 2005, 12:14 PM: Message edited by: Gary Allan ]
