THOMAS R. SMITH
Technical Director, Valvoline Brand
June 7, 2004
To Whom It May Concern:
Valvoline has received several inquiries regarding the topic of MERCON V ATF and its use in various vehicles beyond those requiring DEXRON-III, MERCON, or MERCON V approved products. In response to these questions Valvoline has issued the following statements:
Valvoline supports the use of MERCON V ATF in a broad range of transmissions beyond those requiring DEXRON-III, MERCON, and MERCON V fluids including those where the following fluids are recommended:
o GM DEXRON II
o Allison C-4
o Chrysler ATF+3 or ATF+4 fluids
o Toyota (and Lexus) Type T, T-III or T-IV fluids
o Mitsubishi Diamond SP-II or SP-III fluids
o Hyundai
o Honda ATF-Z1 fluid (except in CVTs)
o BMW LT71141 or LA2634 fluids
o Nissan Matic-D, Matic-J, or Matic-K fluids
MaxLife ATF is recommended for the new 5 and 6 speed transmissions, except the Ford 5R110, Ford 6RXX, and the Mercedes Benz W7A700 (7G-TRONIC) which all require a low viscosity Automatic Transmission Fluid.
Valvoline has conducted in-house testing to support MERCON V ATF performance in these transmissions. However, it is important to note that these vehicle manufacturers have neither evaluated nor approved MERCON V ATF.
Valvoline stands behind all of its products, including MERCON V ATF. Use of MERCON V ATF in transmissions where recommended by Valvoline WILL NOT void the vehicle‼sup>TMs warranty. In the unlikely event that any transmission was to be damaged as a result of the use of MERCON V ATF,
please contact Valvoline at 1-800-Team-VAL.
Valvoline does not recommend MaxLife ATF for use in continuously variable transmissions (CVT‼sup>TMs) or in automatic transmissions where Ford Type F is recommended.
Sincerely,
Thom Smith
Technical Director
Valvoline Brand
http://e34.org/forums/posts/52539
Still not rushing to use it in place of oem Audi fluid, but it's interesting.
I see BMW only sells 20l pails of ATF at 2x the Audi price, yikes!
