Yes, Camu Mahubah, this is where I learned about crank scrapers, same with making my own head gaskets. Mixing my own coolant solutions I learned from a tuna boat engineer.
mechtech2, I remain unconvinced that multiviscosity oil in moderate climate can be considered better without qualification than single grade oil. I do believe that it is a save solution for lubrication needs for most people, not always a better one. If you get involved with your vehicle there are other solutions than the common ones that most fall back on. You can call my old fashioned but you have to remember this 510 is running on the original crank without grinding and the original pistons. There is no way to know if a 10w-30 during the same period would have done better but the single weight oil has done a very good job and should not automatically be considered inferior.
