I bought a used electric hot water pressure washer last fall for a good price. It was not working although the pump had been replaced. I took some of it apart and was half convinced it was the unloader. Its an adjustable unloader and I took it apart and inside it looks clean, no corrosion or obvious wear. But I get almost no pressure with the pump turned on. I am trying to figure out what could be wrong with the unloader besides a lazy spring.
Today I connected up the trigger wand with an inline pressure gauge direct to the output of the pump (no unloader). Keeping the trigger pressed, I turned on the pump and walla, 1000 PSI of pressure water. Its a 1000 or 1200 PSI machine. I guess I will get a new unloader, but just cannot see what is wrong with the unloader. The unloader is about $80, but given what I paid for the non-working hot water pressure washer, its still a steal.
But I still need to make sure the coils and burner work.
