If you have a vice and some known weights you could check the calibration yourself.
For example clamp a nut in the vice, attach the torque wrench horizontally, hang a known weight at a measured distance. Say for example 40 lbs at 18" equals 60 ftlb.
Or tighten a fastener such as a wheel lug nut using the same method and then check the torque with your torque wrench.
There are a lot of variables in torquing a fastener such as surface finish, dry or lubed, etc so the bolt tension you are trying to achieve is never going to be perfect.
