Originally Posted By: vavavroom
Interesting info so far. I have a 36mm socket with a 3/8" drive. A 36mm socket is commonly used for axle nuts. Axle nuts require often around 150 ft lbs. That seems to me a lot of torque for a 3/8" drive. I'd like to rephrase my original question. What's the maximum torque you can put on a 1/4", 3/9" and 1/2" drive respectively without damaging the drive? Let's say you are using a breaker bar, even though you'd likely be using a torque wrench that is rated appropriately.
36mm is also a common size for cartridge oil filter caps, Just like old 1-1/16" sender sockets.....Big hex but not made for a lot of torque.
I use my 1/2" drive impact or 1/2" drive ratchet when tearing stuff down, Break-away torque has nothing to do with what the fastener was originally torqued to.
During re-assembly.....Roofless gave some pretty good guideline numbers, I would fudge the numbers higher for 3/8" & 1/2" when using high quality tools.
1/4" is low torque only. Though I do have some 1/4" drive impact wobbles that I beat the brakes off of with a cordless impact driver!
