Can someone explain to me the tire wear numbers found on the side of tire. The number on my saturn tire is 440 and the number on my Sentra tire is 160. Thanks.
...Not according to the NHTSA.quote:
Originally posted by Patman:
Those wear numbers can only be compared within tires made by the same company, because each company uses a different rating system.
True, IMO I thing some are MORE honest.quote:
Originally posted by Ferb:
-*-*So yes, the UTQG enables a consumer to compare similarly performing tyres. a 360 won't always wear the same as other 360s, but it will wear much better than a 150..
ferb!
WOW...quote:
Originally posted by ryansride2017:
"But yes the 440 is going to wear about 2.5-3, average 2.75 times longer as the 160's
There is a formuala and some tires even have the formula on it, I saw one a few weeks ago getting my alignment."
That's odd. Because the 440 rated tires on my Saturn will need to be replaced at about 30K while the 160 rated tires on my nissan seem like they are going to go to at least 50K. I rotate the tires every 8K miles on each car and wear is even on all tires and across each tire. I thought the lower the number...the better wear mileage out of the tire.
quote:
These tests are conducted INDEPENDANTLY by each manufacturer following government guidelines to assign values that represent a comparison between the tested tire and a control tire
The treadwear number at best gives you a VERY approximate idea of compound softness and expected mileage.quote:
the treadwear ratings are ASSIGNED BY THE MANUFACTURERS following field testing and are most accurate when comparing tires of the same brand.
I wasn't referring to my tires. I know they're A's.quote:
Originally posted by Quattro Pete:
Because the RS-A does not have AA traction. Goodeyear F1 does, IIRC.
Also, this traction rating (B, A, AA) refers to wet traction, not dry traction.
Hey, two can play....quote:
Originally posted by Eiron:
From Goodyear's website:
"Note: Tread wear grades are valid only for comparisons within a manufacturer's product line . They are not valid for comparisons between manufacturers."
The Traction & Temperature ratings, however, are comparable across different brands.
Has too. They can't have some person call a fruit a veggie and another call a grain a veggie. But they can all have their own different veggie and still call IT a veggie.quote:
*-*- While it is not a perfect comparison betw. tires from different manufacturers, it gets you in the ballpark, more or less.-**-
Most car & truck tires are in the 200-400 range of treadwear. Autocross "R" compounds are under 100 but stick to the road like glue. Anything over 400 is a "high mileage" tire that probably sacrifices some traction performance.quote:
