I'm searching for a Tractor Fluid that is wet brake compatible for an automatic transmission, but has a similar viscosity to ATF+4. Any recommendations?
From the info I have read, UTF's should be similar in weight to a SAE20 motor oil, but the specs I've seen don't seem to correlate with that. They seem to be almost double the VIS @40c and 1/3 higher @100c compared to the ATF+4 spec. I'm not sure of the validity of the weight claims though.
