Hyundai 8-speed Wet-DCT 75W Gear Oil VOA
San Diego
Hello folks,
Here is VOA results for Hyundai 00232-19100 "WDCTF Hd G" SAE 75W Gear Oil used in 8 speed wet DCT.
Viscosity at 100C is a bit low compared to similar Ravenol MTF-4 product (5.59 cst).
Ravenol is the only aftermarket oil that I found has this spec, but I could not find it in US. Similar specs:
BOT 233 LVX, Hyundai/Kia 04300-2N100 WDGO-1, Hyundai/Kia 04300-KX1B0, KIA UM015-CH080, VW G 052 549 A2
I was looking at the results and seen zero contamination and then realized it's a voa. Looks like you plan to stay with OEM oil? Since Revenol is hard to find.
Yes indeed, this OEM gear oil is readily available. I will search more for Ravenol sources or alternative ones, but for now I will plan on using this
