This is the easiest espresso maker to maintain. No descaling, backflushing, or anything like that.
All it needs is a wipe down of the stem and brew cylinder o-rings and a very light coating of food-safe silicone (Flair recommends Dow-Corning 111 silicone compound grease) to reduce friction, improve sealing, and keep the rubber supple.
1. Remove the gauge/plunger stem (with this latest version of the 58, it’s just held in by the small pin with o-ring).
View attachment 2007172. Loosen set screw that secures the brew head into the frame, then rotate quarter turn and lift brew head out of frame.
Flair 58 frame with brew head removed:
3. Pop brew piston out of the brew head cylinder bore, remove o-rings, wipe any residue from brew head cylinder bore and piston, apply light coat of 111 to o-rings, and re-install O-rings.
View attachment 200721View attachment 200720
4. Pop piston back into bore, re-install brew head into frame, snug up the set screw, put stem/gauge assy back in, and you’re done!
Takes maybe 15 minutes, and that’s if you take your time doing it!
