Hello Im new here and I have a question about hydraulics. Im also new to heavy equipment. I purchased a TB015 excavator for some home projects and I want to go through it before starting to use it. Im good on everything except for the hydraulics. It all works but the oil tank is a bit low, it has 3k hours and I want to change all the fluid. THe manual does not specify what fluid to use, I see ISO68 available locally is that OK to use?
ALso does anyone know the TB015 setup? It looks like the tank drain is a huge nut (what size is it?) its located in a tough spot and will need a socket for it. Also, is just draining the tank and refilling it enough or is there a way to bleed out the fluid from the rest of the system?
Lastly do I need to prime/bleed the hydraulic pump at all?
Thank You ~ Phil
Thank You ~ Phil
