Originally Posted By: Newtonville
The term mil is commonly used as .001" in labs, shops, industry, etc. A micron is .001 millimeter.
It is sensitive to measure accurately ,0001" even on a hard sample, with a quality mike. Filter media is soft and variable. .001" has no meaning in this case.
The amsoil filter element spread out next to the hyundai is supposed to be about 1/3 the size. That should be verified.
In every US shop and US automaker I have worked with used thousandths of an inch. In every Euro and Asian auto shop book that I have ever used they use millimeters and not microns for measurement, except possibly with crank grinding and the saddle bore end of connecting rods, but again I have not seen it. However, it is not worth arguing over.
When you research filtering media, you will see that the filtering media is very accurate in thickness when manufactured to a given tolerance. The manufactures describe the thickness of their filtering media as 1/64th of an inch or in thousandths of an inch. You can measure all sorts of things accurately with a mic. I and many machinists know that a human hair and a piece of computer paper are around 0.003 of an inch. So if you need to machine a part to 0.001 then you move the cutter up against the part and one it grabs the paper or your hair you are around 0.003 away, you then zero and proceed. Again, it is not worth my time arguing over.
That has been verified. Which leaves me with the question how can their oil filer hold more contaminant and last 25,000 miles with almost 3 times less filtering media. Amsoil gave the following answers:
As for your main question, there are some variables that need to be considered such as:
· The Loft/Thickness of the media that is used.
· Engineering of the filter, Example, AMSOIL only recommends 25,000 mile oil and oil filter intervals when using the filter in conjunction with AMSOIL synthetic lubricants.
· The Quality of Air filter that is being used, along with how often the air filter is being changed. You may or may not be aware, but the air filter is in fact the most important filter in your vehicle.
Along with these variables, AMSOIL has also conducted independent studies that have show the Ea oil filters to be working properly beyond 25,000 miles with AMSOIL lubricants.
Regards,
Bryan Kershaw
AMSOIL Product Specialist
Filtration/Aftermarket
I had more follow up questions that have yet to be answered.
