Have just had a 10,000 lb 2 post lift installed, the manual calls for Dexron III Atf. Would there be any benefit to use synthetic ATF such as Amsoil in this application? Area lift is located is currently unheated with temps down to 0*F though I will be running a salamander to warm things up a bit in the winter if I need to be out there. Hopefully in the next couple years will have IR tube heaters but for now making do with what I have.
