Currently I'm an owner of a 2006 Audi A3 with an 02Q six speed transmission. The OEM fluid is the G52 ( G052 911 A1) which is spec'd as a GL4/5 and has a VW 501.50 rating. IIRC this is a 75w90 gear oil.
Currently the vehicle has 2800 miles on it and I'm thinking about
switching it out for some redline MT-90 or SF MTL-R. The reason why I'd like to switch is because during certain shifts, I can "feel" the gears more than on other shifts. I do not launch the vehicle or rush through the gears so I'm fairly aware of being nice on the syncros. What I would like is a slightly thicker oil / better additive package than the OEM fluid. From what I've seen, the MTL-R has been used in various VW transmissions with no issues at all.
MT-90 seems to have its fair share of haters in the NE due to cold shifting issues. The supposedly "fix" for this is to blend it with some MTL, however it has worked for some and hasn't worked for others. I live in the Northeast in an area which gets down to as low as -20F so cold shifting is an issue.
Although I could not find the specs on the OEM fluid, I did find that Castrol makes a VW501.50 gear oil called TAF-X and I could get the specs on that. According to Castrol, TAF-X is the factory fill for VW/Audi. Assuming that it is the OE fluid or similar to the OE fluid it appears to have a much lower viscosity than the MT-90/MTL-R @ 40 degrees.
Sorry for the weird language but it was the only specs I could find.
????????? ??? 15 ? ?, ?/?? 3 0.864
???????? ??? 40 ? ?, ??? 76.0
???????? ??? 100 ? ?, ??? 14.0
?????? ???????? 200
??????????? ??????? ? ???????? ?????, ? C 224
??????????? ??????????, ? ? -51
In my situation, should I swap out the fluid to the MTL-R or stick
with OE fluid? I'm sure the TAF-X is an excellent gear oil, but I'm
sure the additive package in MTL-R is most likely better. I'm hoping a switch in fluid would make the shift feel more consistant and also reduce wear in the transmission but am worried about cold shifting. Any comments / insight would be greatly appreciated.
Dave
?????? ???????? 200
Dave
