Your friend's one anecdotal case doesn't discredit Ram's findings.My farmer friend has a 19’ Ram 2500 diesel truck, runs 15w40 year round with ZERO issues that’s 0.
RAM didn’t publish findings. It published a general warning. A warning that on its surface, appears to make zero sense based upon the criteria they listed.Your friend's one anecdotal case doesn't discredit Ram's findings.
As JustN89 stated Stellantis/Ram didn’t publish any findings so until they do I wouldn’t believe them at allYour friend's one anecdotal case doesn't discredit Ram's findings.
They're not obligated toAs JustN89 stated Stellantis/Ram didn’t publish any findings
Just playing devil's advocate - what ulterior motive would they have for publishing this TSB ?so until they do I wouldn’t believe them at all
Better question: why did they wait until now and go back to 2019 models. I repeat what I said earlier: I smell a rat.They're not obligated to
To you it may not make sense. But they may not be giving all the data, post-mortem assessments, etc. may not ever for certain liability reasons.RAM didn’t publish findings. It published a general warning. A warning that on its surface, appears to make zero sense based upon the criteria they listed.
They may never publish “findings” because it results in an admission of guilt and this opens to liability. So this point is moot.As JustN89 stated Stellantis/Ram didn’t publish any findings so until they do I wouldn’t believe them at all
Agree until you realize that most folks aren’t informed, nor care, as much as people here. I suspect it’s hard to get all consumers to run an HDEO, let alone one that is a few dollars more money.Adding a more simple view to my already stated thoughts a few pages back:
Viscosity is merely a quantification of a fluid's resistance to flow; nothing more and nothing less. The intended manipulation of vis in a lubricant can be achived by several means, not the least of which is basestocks AND/OR VIIs. To condemn a lubricant solely based on vis seems incredibly short-sighted and uninformed in this situation.
And people thought the Ford diesel oil list was confusing and made no sense ... I believe Stellantis has usurped the Ford topic and raised oil stupidity to a new level.
It's not a matter of my opinion and whether or not it makes sense to me. Viscosity alone (the only reason they gave) has no correlation to the formation of deposits.To you it may not make sense. But they may not be giving all the data, post-mortem assessments, etc. may not ever for certain liability reasons.
I don’t care what some folks here “say”. They are simply backing Ram. Show me actual proof instead of total BS. I can care less if my friend is using conventional 15w40 or whatever. I have like many friends with this truck and engine using store brand 15w40 oil. I want proof not some stupid TSB with no backing. That’s called misinformation. Awful funny that the Cummins 6.7 engine is pretty reliable and now RAM says don’t use 15w40. Get real. I want facts not opinions.It's not a matter of my opinion and whether or not it makes sense to me. Viscosity alone (the only reason they gave) has no correlation to the formation of deposits.
Now, 15W-40 can be found in a conventional oil, unlike 5W-40, and the use of conventional oil could lead to increased deposits. This would explain their statements. However, that takes inferring their intention by use of what might not be exceptionally common knowledge (how many drivers on the road actually know the pros and cons of synthetic vs conventional and what grades are often found in conventional and what grades can only be found in synthetic?). Essentially, RAM could be correct in warning people off of 15W-40, but because of the reasoning they gave, they're actually just simply wrong. If they didn't want to say what the actual reasoning was, they would've been better off just saying "use of 15W-40 engine oil will cause damage". No reason needed, especially an incorrect reason.
They will never be honest with their consumer. That’s common sense. They should be forthcoming and open and honest. Oh I just spoke truthTo you it may not make sense. But they may not be giving all the data, post-mortem assessments, etc. may not ever for certain liability reasons.
Haha. I've never owned a Chrysler product or whatever they're called this decade. I have ZERO connection to them or their products. I just think it's hilarious that this has turned into a conspiracy !!I don’t care what some folks here “say”. They are simply backing Ram.
All I’m sayin’ is that if people have been using 15w40 for how long day 2018 without issues, why change.At the end of the day, 90% of Ram/Cummings owners that do their own oil changes will keep using whatever oil they want. Maybe it will be what the owner's manual says which is now superseded, so plenty will continue to use 15W-40.
You know of (1) example. Chrysler knows of thousands or tens of thousands and maybe, just maybe, they're seeing issues. Well, clearly they're seeing issues ! Maybe, just maybe, they looked at what oil was used in a pool of samples they analyzed and maybe they saw a common denominator.All I’m sayin’ is that if people have been using 15w40 for how long day 2018 without issues, why change.
I understand your comments and don't disagree in how you see the "uninformed" public ... but the entire release is either poorly reasoned, or poorly written, or a combo of both. No LOGICAL engineer at Cummins had a hand in that release. I have a cousin-once-removed who works as an engineer for Cummins in Columbus; I'm going to reach out and ask what's going on. He does not work on the 6.7s, but he probably knows someone who does. If there is info he can share, I'll update us. But, it may be privileged info and not open to the public.Agree until you realize that most folks aren’t informed, nor care, as much as people here. I suspect it’s hard to get all consumers to run an HDEO, let alone one that is a few dollars more money.
I suspect that forcing the viscosity is a way to getstupiduninformed folks to buy the right product.
