Snap-On vs. Matco vs. Gearwrench Metric Universal Impact Extensions
I did the opposite. I only need the 10mm and 14mm sizes, so I'm getting them from my SO dealer. He offered me a price that was more than 30% under list, so I can live with that.
Update- I ended up buying the entire set from my dealer for a more than reasonable price.
I have been using the heck out of the 10mm and 12mm - anytime I need additional length that requires an extension, these have become my first grab.
Wow, is that a tool you will use regularly? It's not something I'd use often.
Came in handy today:
Probably one of my better tool purchases. The 10/12/14mm live in my top drawer and see a lot of use. For whatever reason, their overall length of 9-10” seem to be the perfect length for the situations where I normally seek a socket + extension.
Just an update on the Matco pinless. I commonly use 1 1/16" universal socket on a 1/2" drive Milwaukee Fuel. I use it almost daily for tightening 5/8" studs with heavy duty nuts. The universal lasted about 2 months before is got tight and locked up. Tried a second socket lubricated with RP assembly lube, same result. I also have a 1/2" drive by 1/2" drive Matco pinless universal for use with a 1/2" drive socket. The socket seems to add just enough slop to lighten the impact slightly which helps the universal life, and I'm three months in on this socket.
My 1/4” Matco pinless swivel sockets are holding up very well. But that is different than the 1/2” arena.
I think the design isn’t well suited to higher torque applications, but I could be wrong.
