Originally Posted By: BrianWC
Originally Posted By: Astro14
I actually thought it sounded OK in the video...
But "sounds like a B52..."? You should be so lucky...the B-52 has 8 turbojet engines...and makes a sound like roaring thunder...everyone, and I mean everyone, would get out of your way with that sound...
Maybe you meant a B-17 (big radials...unmuffled...)...
As someone in the flightpath of the largest B-52 base (in the whole danged air force), I can testify that flowmasters don't do that noise justice.
Yes it sounds great in the video, brand new, not "seasoned" yet. Even now when seasoned it sounds good revving out.
Yep you got me. I don't know jack about airplaines. I'll take your advice and call it a B-17 from now on.
Originally Posted By: jeepman3071
The dynomax will sound much better. If you think the Flowmaster annoys you now, wait a week. I had one on my Jeep and thought it was cool when first installed. A month later I ripped it off and put on the Dynomax super turbo.
Yep, it was about a week and 200-300 miles that it got much worse. It is definitely seasoned now.
Originally Posted By: mechtech2
Cut a bit of a slash on the exit pipe. Angle it towards the ground. 45 degrees - but just a partial , not a sharp tip on top. Do you have a resonator? If not, it will help a lot.
Drone is annoying.
I don't think it will help that much the resonation is in the muffler case, apparently designed that way. Need half inch of heat proof spray on insulation. No resonator, was removed with stock muffler. I don't plan on resonator with the Dynomax either.
I even had a 8.5" pipe of approx 1.4" diameter mounted inside the tailpipe, with the between area blocked--still way too loud.
