I failed inspection last week due to a frayed seat belt. Found one in a salvage yard in CA... just arrived by post today. I proceeded to take out the old belt, and started to install the replacement. The lock on the retractor of the replacement wont release, and as a result, I can't even get the belt far enough out of the retractor to bolt the top connector to the side of the truck. Is there a trick to get it to release? I've already tried retracting even more belt to see if it would let go... no dice. In fact, there is so much belt retracted now that no more can be accomodated in the retractor (the roll of belt is as big as the retractor can hold).
1999 Toyota Tacoma Extra Cab V6
Driver side belt
part number 73220-04090
PS - the old belt that I took out is showing the same behavior now that its out. It worked fine before. There must be a trick to get them to release?! Help me, I'm bleedin'!
Driver side belt
