I will be replacing the sdf-10 on my wifes 93 Corolla 1.8 & the sdf-57 on my geo 1.3 with sdf-15's. Both cars are running amsoil s2000 0w-30. How much additional oil will this add to the system?
Does anyone have the flow rate/ contaminate holding capacity numbers on these filters? Reasons for going to larger filters are 1. easier cold weather flow. 2. more filtration area/higher filter capacity. 3.Increased oil capacity. 4. better filtration since the same volume of oil will be spread out over several times the area of media. 5. filters cost less. 6. I can use a real filter wrench
Does this sound like I'm on the right track or am I missing something? Is there any negative aspects to doing this other than the additional cost of makeup oil? Both cars have room to run this filter, could even run the sdf-26 but don't think it would be cost effective over the sdf-15. What do you think?
Thanks,
Steve
Thanks,
Steve
