Here ya go:
Valvoline Non-Detergent Motor Oil SAE 30 is a general purpose non-detergent engine oil. It is blended from premium base stocks with additives which provide wear and oxidation inhibition. Valvoline Non-Detergent Motor Oil SAE 30 is recommended for manual transmissions and gear boxes which do not require an extreme pressure gear lubricant. They are good lubricants for general purpose use and for some hydraulic systems. They can be used in selected older engines where the manufacturer recommends API SB or MM engine oils.
Valvoline Non-Detergent Motor Oil SAE 30 does not meet the performance requirements of any modern engines.
The Valvoline Non-Detergent Motor Oil SAE 30 Advantage:
Good general purpose lubricant as well as a hydraulic fluid for use in some hydraulic systems.
Approvals/Performance Levels
API SB
Air Compressors
Hydraulic Systems
Racine Vane Pumps
Denison HF-2
Vickers I-286S
Viscosity @ 100°C, cSt 11.0
Viscosity @ 40°C, cSt 107.0
Viscosity Index 95
Specific Gravity @ 60F 0.889
Density (lbs/gal) 7.40
Flash Point, COC °F 445
Zinc, wt.% 0.04
Pour Point, °C -18
Ed
