Originally Posted By: NHHEMI
2 - 70K in a 400+ HP engine that has been used as hard as you claim is
NOT something just any modern oil would hold up to as some claim and return the results you have seen.
Incorrect.
Plain-Jane Mobil 1 0w-40 is specified for Porsches with way more than that, including turbocharged ones.
Even plainer-Janer Mobil 1 5w-30 is specified for the Corvette, and that hasn't been available with less than 400 hp for years.
I know what you meant -- i.e. you can't just toss in grocery store oil and have it work -- and you're probably right. But that's not really relevant, is it? The fact is that in this regard, RP is nothing special, and there is nothing to suggest that it performs any better than some cheaper oils.
Also, the RP street oil you are using is an API SL oil which contains a higher level of ZDDP vs the current API SM oils out there so it actually is a better choice for your high HP hard running engine.
Since when is ZDDP the only thing that protects against wear? SM is stricter with respect to wear control, as well as oxidation resistance, deposit control, foaming, low-temp performance, etc...
I would not say as others have that the results RP returned for you were nothing to get excited about because any modern oil could do it. That just shows a lack of knowledge about how hard your kind of use is on an engine.
If you're concerned about saying things without appropriate knowledge, why would you say that your experience from the 70s applies to modern engines?
Amsoil marketing = [censored].
The worst you could say about their advertising claims is that they are irrelevant. At least they involve repeatable tests on industry-standard equipment that anyone can check.
If you haven't used a product it escapes me how you can tell others it is bad?
Well, have you tested every single API-certified oil on the market in the OP's engine? How can you claim they won't work?
This site is a great resource but don't let others talk you out of or into anything
So, why are you posting?
