W WillB Joined Jul 31, 2010 Messages 351 Location Innisfil, Ontario, Canada Nov 22, 2014 #1 Can I run this coolant in everything? atv? diesel tractor? Gas truck eventually? Rotella ELC. Last edited: Nov 22, 2014
T Tanama Joined May 29, 2013 Messages 70 Location KY, USA Nov 22, 2014 #2 I believe the answer is yes, you can run Rotella ELC in most internal combustion engines. You can normally use diesel formulated coolants in gasoline engines. But, using gasoline formulated coolants in diesel engines is not a good call.
