As a result from a recent accident, my DD is down for awhile until further notice. It is a 2004 Tacoma and I'm more than upset about it being down. The only other option I have for getting to work and doing other odds and ends is my 7.3 Powerstroke. Truck's only ever been used for hauling trash, towing cars around, and occasionally hauling the wife and I's quads out to the mountains for a weekend getaway. Other than that it sits most the time. It currently has 184k miles and as far as I know has been fed nothing but conventional 15w40 it's whole life. It's approaching it's next oil change and I've decided I want to give it something better this time around since it will be getting driven for awhile. Been running Rotella T 15w40 conventional since I've owned it and changed it once a year because it never got the miles put on it to justify anything else.
Only concern I have about T6 is that it may cause the old seals to leak, 7.3's are known to be leakers. I did some further research and discovered Rotella offers a synthetic blend T5 in the 15w40 grade with longer drain abilities and better cold start flowing. Something that is highly necessary here in Montana cold winter mornings! Should I go with the T6 or T5? Truck doesn't leak much now luckily but I don't want that to change. Never had problems with synthetics leaking in my Tacoma, but it only had 74k when I bought it and is only 12 years old, my Ford's pushing 20 already.
Thoughts?
Thoughts?
