Originally Posted By: Doog
Originally Posted By: Boomer
Do you hunt a lot in rainy weather? Do you wipe your stock down after a day of hunting in the rain?
I think tung oil is OK for a showpiece/take it to the range gun. But for a serious hunter who is exposed to all kinds of weather, a matte finish waterproog outdoor urethane is really a must if you want to protect the wood stock.
The stock is off an old marlin and going on another one that is custom. So it is a straight bolt on. But I will use it in all types of weather so durability is #1 so I think I'll take your advice on the urethane finish coat maybe in a semi gloss and do 3-4 coats with 0000 steel wool in between each coat.
A friend of mine recommended 2-4 coats of marine grade urethane to stand up to weather and some abuse.
I would just make sure that you can find a marine varnish that is not poly. If you ding or chip the finish, poly is very hard to repair. Most of the time you will have witness lines. I would recommend Epifanes and I would put on gloss. You can then use paste wax and 0000 steel wool to adjust the gloss. You can always de or repolish to a glosss as long as you start with gloss. You cannot polish up semi or satin.
