No. Now, we don't get what you guys call "top tier gas". Until about 6 months ago, Premium was just a higher octane. It's only in the last 6 months they've started advertising the "cleaning" abilities of their premium fuel.
I love SI-1, and I use it on the second last tank prior to my yearly oil change. Having said that, I also keep an eye on my injectors and while the SI-1 helps clean up very mild deposits and keep a reasonable spray pattern, it does 2/10ths of bugger all for grungy injectors. I tried that by putting dirty injectors that I'd already tested for spray pattern in the car and running 3 tanks of SI-1 in a row. When they came out they were just as bad as when they went in.
It does seem to help keep intake valve deposits under control, but again it's a feeling. Every year I pop an injector out and have a poke around with a borescope, and since I started using SI-1 the valves seem to grow fewer deposits.
If you have dirty injectors, clean them properly (or pay someone to do it).
