This is the 2004 S2000 with the North American 2.2L engine that revs to 8400rpm and produces about 250hp according to dyno results, sump capacity 6 quarts, OEM Honda oil filter that's designed only for this Honda model with high flow capacity.
Dumped the break in oil at 2000 miles, then used this oil for the next 4,000 miles. The car was driven hard, with "normal" shifts around 3-4K rpm and many trips to redline and other high revving manouvers.
A mix of city and hwy, with hwy speeds usually around 70-80mph at 4500rpm with some trips to 100-120.
Added 1/2 quart in the first 1400 miles of the interval, haven't added any since then.
Had construction on my street for most of this interval, tons of dust and dirt which might explain the elevated silicon. Otherwise I think Redline did a good job considering the high revving, high stress environment this engine was put through and because the engine is still breaking in. I like how the oil stayed in grade (Redline lists at 10.7 cSt). I changed the oil "early" because it was the first oil change and I also wanted to have fresh oil in the engine before I store the car for the winter.
Comments?
[ November 26, 2004, 09:12 AM: Message edited by: Quick_lude ]
Comments?
- Iron (Fe) 9.8
Chromium (Cr) 0.5
Nickel (Ni) 0.1
Titanium (Ti) 0.1
Silver (Ag) 0.5
Aluminum (Al) 7.2
Lead (Pb) 3.3
Copper (Cu) 27
Tin (Sn) 0.2
Silicon (Si) 24
Sodium (Na) 17
Potassium (K) 0.0
Boron (B) 17
Barium (Ba) 1.6
Molybdenum (Mo) 586
Magnesium (Mg) 9.7
Calcium (Ca) 2760
Phosphorus (P) 1143
Zinc (Zn) 1275
Sulfur (S) 4757
Manganese (Mn) 2.2
Vanadium (V) 0.6
Oxid(PA) 118
Nitr(PA) 47
Sulf(PA) 288
TBN 6.21
Kv@100°C 10.6
