I could be wrong, but based on some engine flow rates I've seen for oil, it's moving very slowly and thus "restrictions" offer less of a restriction than one might think.
Some high performance engines can pump 10~12 GPM at high RPM. That's like circulating a 5 qt sump through every 8 seconds. I wouldn't call that oil "moving slowly".
True. However "most" vehicles are less than that and dependent on RPM as well (that's if there fixed-displacement, which many are). Seems new cars are moving towards variable-displacement pumps so lower overall pressure and flow.
Lots of high performance cars these days still have pretty high output oil pumps. Subaru turbos put out something like 14 GPM at redline. There have been many threads about the high oil flow in Subaru's, and many people concerned about the filter's high bypass setting (around 23 PSI) because of it.
And yes, it all depends on the engine RPM if a positive displacement oil pump is used, but who's gonna cruise around at half the redline all day because they think they have a restrictive oil filter on the car. If an oil filter can't take full redline RPM without going into bypass (due to huge filter delta-p), then they should even be making them for everyday cars on the road. Plenty of people drive their high performance cars hard on the street.
This whole thread was about someone who was concerned that using a PureOne under high RPM conditions would push the filter to bypass. Apparently Purolator was so interested in this that they actually ran a bench test to prove it wouldn't.
PureOne Flow vs Delta-P Data
I've seen that thread, but it's "old"... does the Purolator they tested back then apply? I thought this was a recent change (punched slit center tube)?
